Reply
Frequent Advisor
0
Accepted Solution
Alternate firmware possible for MyNet N900?
I know this is a long shot, but are there any alternate firmware choices for the MyNet N900? I'm not looking for additional features -- just plain old reliability. By 'alternate firmware", I'm referring to dd-wrt and the like. Thanks.
Honored Contributor
0
Re: Alternate firmware possible for MyNet N900?
As far as I know, only the official firmware is available .
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
Occasional Visitor
0
I assume the same for the N750? (not compatible with dd-wrt)
Occasional Advisor
0
SOrry - Not likily that tomato or ddwrt would ever be availible for this device since its the wrong chipset.
