Need FTP help
Hey everyone,
just got my mbl and set it up. everything seems to be working, its great getting everything onto the network. I have been trying to get FTP working and have run into some problems. I forwarded the HDs ip to port 21. I went into filezilla and used passive mode and put my public IP and username/password and I got this error. any help is appreciated.
Response: 230 Login successful.
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Features:
Response: EPRT
Response: EPSV
Response: MDTM
Response: PASV
Response: REST STREAM
Response: SIZE
Response: TVFS
Response: UTF8
Response: 211 End
Command: OPTS UTF8 ON
Response: 200 Always in UTF8 mode.
Status: Connected
Status: Retrieving directory listing…
Command: PWD
Response: 257 “/”
Command: TYPE I
Response: 200 Switching to Binary mode.
Command: PASV
Response: 227 Entering Passive Mode (192,168,1,8,19,199).
Status: Server sent passive reply with unroutable address. Using server address instead.
Command: LIST
Error: Connection timed out
Error: Failed to retrieve directory listing
Hey
Just wanted to let anyone who is having the same problem know I got it working.
There were a couple things I did…but one thing for sure needed to be done
Most importantly, dont try to ftp from your own LAN…i thought I would test it out on a separate network so I tethered to my Nexus One and filezilla worked
I also used a static NAT for the local IP and forwarded port 21
I THINK you have a problem on your router.
I assume you’re trying to FTP from OUTSIDE your network?   Meaning a “remote connection?”
If so, your router is not functioning as an APPLICATION LEVEL GATEWAY, or ALG.
The My Book Live is (CORRECTLY) responding with a command to enter PASSIVE mode, and telling the client to use the IP address 192.168.1.8 for that connection.
192.168.1.8 cannot be routed on the internet, so your ROUTER is supposed to translate that IP address to ITS OWN address which is visible to the rest of the world, and then forward the FTP packets that come to it back to the server.
What kind of router do you have?
