Does not happen anything when I try to open Public folder from WD quick view utility directly, and when I try to map the folder or open it from a shortcut it ask me a psw, but I have not a psw set on my device.
I had the same result on a different router with different PCs.
if you mean the same DNS Server adress both in ethernet and wireless yes, my router works as DNS serves as well (and I can’t set different DNS for ethernet and wireless).
i just had the same problem, i wouldn’t see my drive anywhere. i connected my drive directly to my pc deleted my network card and restored by itself…now its all good thanks
