My external hard drive My Book Live does not connect. when I connect to network cables, i saw green light when the network connection. when I connect the power supply blue light. then begins te make several times noise. a kind of tick sound. then goes to red light. I also hear some times the sound. then will continue kluer red light on.
normally that will a green light. then it make well connected with computer via network. that does not happen now.Therefore I think there is some trouble in mt hard disk… How can I fix this error? because the data that I have on this hard disk is very important. I need them.
I would like to find a possible solution to restore it. I have several times used the reset button. I have done according to the instructions of the harddisk.
please give me a sollution.
