JediJD
1
Hello
I am new on this forum.
I am a photographer and I set up a network with a My Book Life and 3 PCs
2 PCs under Vista or Windows 7
1 PC under Windows 8
I found the set up some how too slow to present the pics.
How can I speed up the system ?
Thanks for you help
JD
the speed of your network, it depends on the network device, which is usually your router.
Also, Wifi is slower than wired.
I would start there, wired a PC and try it. If it has positive results, wifi might be your issue.
But also, there are a lot of factors involved. Here is some reading:
http://www.tomshardware.com/reviews/gigabit-ethernet-bandwidth,2321-3.html
For Wifi speeds]:
http://www.speedguide.net/faq_in_q.php?qid=374
