I was copying some files into my MBL and decided to disconnect abruptly from the plug connetion as it froze.
Upon restarting MBL, I have been uanble to access it and the dashboard.
I am absolutely sure ssh was enabled, but putty cant access it.
My router normally shows the MBL connection which no longer does.
WDlink cant find address.
Power cycle done—lost count
Any helpful suggestion will be highly valued.
thanks guys
