Hi All,
I need some advice and help.
I have been using my MBL 3TB for just over a year. Never had a problem with any WD products before.
However now My MBL 3TB cant be find on my home network and worse still its stuck in a cycle of trying to reboot itself.
When i power up the MBL it will start with a Blue Light,
then it will stay on a solid yellow light,
it turns blue again after about 20 mins,
but then back to RED or solid YELLOW again.
I have tried to take some advice given to others however i cant even access My book live dashboard to open the SSH to try and use PUTTY but couldnt get around the problem.
Can someone tell me has my MBL died or can i do something to either get my data or to get it up and running again.
Thanks in advance.
A
