I have seen several requests for an easy to follow guide on how to Factory Restore a MyBookLive when the Dashboard is throwing errors and won’t let you do anything, so here it is.
Please note that this guide will not delete any data on your data partition but you will need to follow the steps at the end of the guide to re-link your shares.
In a web-browser go to http://mybooklive/UI/ssh and you should see the following. Tick SSH Access Enable
enter welc0me for the password (Continue on to step 5)
Open PuTTY and enter mybooklive in the Host Name (or IP address) box and click Open
Now we need to enter the login information
type root for the username and hit enter
type welc0me for the password and hit enter
(The password text won’t show up in the PuTTY window)
Now at the MyBookLive:~# prompt you are gonna type
/usr/local/sbin/factoryRestore.sh noreformat
wait a minute
and then type
reboot
Wait for your MyBookLive to reboot and when it does, go to the Dashboard and you should see
Factory restore complete and you should now have full dashboard access
If your shares are still listed in the MyBookLive dashboard but are not accessible, rename the shares and then rename them back to get them linked properly again.
EX. Movies > Movies1 > Movies
If your shares are missing in the MyBookLive dashboard, recreate them in the dashboard and you will be able to access your data again
A reboot is required to get the share and drive usage totals to reflect the actual data usage after these changes
____________________________________________________________________________________________________
No data will be lost… noreformat at the end of the command “/usr/local/sbin/factoryRestore.sh noreformat” prevents the script from deleting the data on your data partition.
32111 - Error creating user: Failed to create user account. Please make sure you have the required privileges and sufficient disk space for this operation and try again
Have you put any data on the drive yet? If not, try doing a quick factory restore from the dashboard to see if that clears it up. Just note that this WILL delete any data you have put on the drive.
Seems some people are getting new drives out of the box with a newer firmware version (02.32.06-006-20121010) on it than what is available online. Not sure if the new firmware version is the problem or not… Firmware upgrades have also caused people to experience this issue.
I joined this AM, and right out the box, my issue has been corrected. Not sure who specifically to thanks, but thanks to the user/knowledge base for the help. My device no longer hangs up, and I have access to entire dashboard to create users and remote access priveledges.
1 question - The “SSH” that I enabled in the begining of this thread, do I have to disable it now? With it enabled, am I “exposed” so to speak? Thanks.
Yes, it could be a security concern. Obviously don’t forward port 22 to the MyBookLive on your router. If you do decide to turn it off and lose dashboard access, you won’t be able to repair your OS without taking the drive apart.
Having said that, you can turn it off after you follow my guide below so that a simple press of the reset button would enable SSH access if you were to lose dashboard access and weren’t able to enable SSH from the dashboard to fix it.
Thank you. Please pardon my ignorance. If I turn it (SSH) off/disable, will it affect my remote access priveledges or anything else relating to routine access and use? Thanks.
