Does anyone know if it is possible to connect the WD Live Hub to a 3TB mybooklive directly using smb so that I can access iso files. The Hub sees the mybooklive twonky fine, but I can’t connect via smb. I need to run this in an off grid cabin (generator).
Tried using a router to assign ip’s , which let the hub see the mybooklive in the smb list, but it would not authenticate.
I assume there are some router settings I need to configure?
