My device doesn’t mount disks after a power failure. Attached one of the disks to a Linux box and tried to mount it without success. It seems like the superblocks are missing. Any help is greatly appreciated. I’ve removed one of the disks as a backup. Currently disk A is in the device.
md2 : active raid1 sda3[1]
500724 blocks super 1.0 [2/1] [_U]
md1 : active raid1 sda2[2] sda1[0]
1999808 blocks [4/2] [U\_U\_]
MyBookLiveDuo:~# mount /dev/md3 /mnt/
mount: you must specify the filesystem type
MyBookLiveDuo:~# mount -t ext3 /dev/md3 /mnt/
mount: wrong fs type, bad option, bad superblock on /dev/md3,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
MyBookLiveDuo:~# dumpe2fs /dev/md3
dumpe2fs 1.41.12 (17-May-2010)
dumpe2fs: Bad magic number in super-block while trying to open /dev/md3
Couldn’t find valid filesystem superblock.
It does boot. The device is running with a single disk right now. The problem is, it doesn’t mount the data partition (md3) And I can’t access my data.
BIGNAS3:~# dumpe2fs /dev/md3 |grep superblock ; dumpe2fs /dev/sda4 |grep superblock
Primary superblock at 0, Group descriptors at 1-1
Backup superblock at 65528, Group descriptors at 65529-65529
Backup superblock at 196584, Group descriptors at 196585-196585
Backup superblock at 327640, Group descriptors at 327641-327641
Backup superblock at 458696, Group descriptors at 458697-458697
Backup superblock at 589752, Group descriptors at 589753-589753
Backup superblock at 1638200, Group descriptors at 1638201-1638201
Backup superblock at 1769256, Group descriptors at 1769257-1769257
Backup superblock at 3210872, Group descriptors at 3210873-3210873
Backup superblock at 5307768, Group descriptors at 5307769-5307769
Backup superblock at 8191000, Group descriptors at 8191001-8191001
Backup superblock at 15923304, Group descriptors at 15923305-15923305
Backup superblock at 22476104, Group descriptors at 22476105-22476105
Backup superblock at 40955000, Group descriptors at 40955001-40955001
TonyPh12345, that information helped me save my data. Thank you, I really appreciate it.
For anyone who has the same problem, here is what I did:
Attached one of the disks to a PC. Normally dumpe2fs should show the superblock locations but for some reason it didn’t work. Using Tony’s dumpe2fs output, I’ve used 65528 with e2fsck:
e2fsck -b 65528 /dev/md0
It askes lots of questions, I’ve said yes to all.
After that, it was ready to mount. But it didn’t mount on a PC, you need a Power PC to mount it. So I’ve attached it to My Book again and ran:
