Problem connecting with wdtvlive for watching videos
FOund my problem. Turns out I rebuilt the indexs on my Duo and it turned on everything.
The message from WDTV Live is grossly incorrrect, it said that the movie was not the proper format, when actually it was a “TIMEOUT”.
After much work, I turned off DLNA, Itunes, energy saver and everything now works correctly.
WD needs to fix that error message.
Thanks for posting your workaround.
