The led light on the front of my duo is not on, nor does it come on at all. Not even during boot.
The drive is functioning fine. I can access everything.
Any ideas why it is off?
If everything else is working fine then it’s possible the LED just burned out.
The unit is less than a month old. Is there a setting to enable it?
Unfortunately the unit does not feature LED controls.
