I Created a User named steambackup (For my steam games obvsly) with the Password backup (to be changed now)
if i want to log in with my Windows pc and enter the login name and password it wont work , is there any way (or command for SSH) to see what happens during the process of creating the user in the interface?or is there already a solution?
Greeting
Germanfragger
If you’re on a Windows-based PC, you won’t be able to log into multiple users at the same time on the MBLD. “Guest” counts as one, if you’re connecting to Public shares.
Is that what you’re trying to do?
yes sort of because i got multiple shares for some backup operations (Steam/windows/data)
and i need to connect to all of them or 1 at a time! so how can i do that (Disconnect user Steam and connect user data?)
Why put them in different users? Just use the same user as the other shares you’re accessing.
