Reply
Occasional Contributor
palmzupent
0
clicking noise
when i turn on my hard drive it comes on but its making a clicking sound like a cd is skipping and its not registering on my p.c
Honored Contributor
Joe_S
Re: clicking noise
What drive and OS are you using? If it's a USB powered drive try different ports without a hub and anothher cable if possible. If it's a powered drive plug into a different outlet without surge protector.
Joe
Click the Kudos star to say thank you for helpful posts. And be sure to come back to click the 'Accept as Solution' button for the post that solved your issue.
palmzupent
0
Re: clicking noise
it has a usb and a power cord but its not showing up on my pc sombody told me it might be the mechinical arm if so is it fix able
Respected Contributor
Wayne
0
Re: clicking noise
if the drive is clicking, and doesn't show up in disk management, then it has most likely failed.  if you need data off the drive, you will need to do data recovery.  however, if the drive isn't getting enough power it might click, also.  disconnect the data cable, plug the power adapter directly into a wall outlet, and see if it spins up without clicking.  if it does, then plug the drive back into the pc to see if it shows up.  if it doesn't then it's failed and needs to be replaced.
Occasional Visitor
MapleLeaf
0
Re: clicking noise
I have the same problem with My Book Live; after the power went off one day it stopped working and now it makes a funny noise. The light looks like a yellow, not a solid green at all. Does this mean I lost all the data on the drive? Can i get it replaced?
I am so mad, I have only used it for one month. Paid so much money to lose all my family photos in an instant...?
Wayne
0
Re: clicking noise
[ Edited ]
first of all you should be spanked for having all your important photos on one drive.  :smileyvery-happy:  when the light is yellow, it means that the drive is trying to boot.  it could be because it needs more power.  trying plugging the drive directly into the wall to see if that changes.  however, since you had a power outage, it is possible that you got a power spike that damaged the drive.  if the drive doesn't start up when you plug it into the wall, then it's most likely failed, and you will need some kind of data recovery.   if you don't care about the warranty, you could pull the internal drive and put it in a linux computer to see if you can access the data.
palmzupent
0
Re: clicking noise
how do i do the data recovery
Wayne
0
Re: clicking noise
you can find a list of data recovery companies on wd's support page.
