Accessory hard drive AC power supply
Please excuse me “jumping in” to your site, but I’m at my wits end!
I’m hoping someone can help this “TechDummie”!
I back-up all my work files onto an accessory HD thinking they are “safe”.
Well, now, I’ve been told the power supply switcher has gone bad…
so, now I can’t get anything off of it!  AARRGGHH…
Does anyone know how to find the following cord?
I’ve been online searching for hours, even emailed a place in China (stilll waiting to hear from them);
but have had no luck at all finding one…except one on eBay that is now SOLD!   Bummer!
OK, this is what I need for my Western Digital Accessory HD–Model #:  WD25008012-RNN:
ITE Power Supply
Model #:   AC-005W
Input:  100-240Vac,1A,50/60Hz
Output:  +5V–/2.sA,+12V–/1.5A
Importer:  Omni Co. Ltd
US Listed:  E235587
THANK YOU FOR ANY HELP YOU CAN OFFER!!!    I’m desperate!!!
What make and model is the drive? I can’t find the model# you give above anywhere online.
Hi!
Thanks for asking!
The best I can read these itsy-bitsy numbers are:
WESTERN DIGITAL
MODEL #:  WD25008 (OR B) 012-RNN
SERIAL #:  [edited]
ORDER #:  WDXF25u0JBRNN
Thanks again!
Power Cables
Yep…  Good find, Wizer…
OP’s model appears to be discontinued.
Hmmm, so this mean that since my device looks to be discontinued, that I still can NOT get just a power cord for it?
Sorry!!   THis is why my name is “TechDummie”!:grumpycat:
Thanks!!
You might try contacting tech support…
You should also be able to find a generic power adapter that will work.  You just need to make sure that the output voltage, amperage, and connector is the same.
