Wrong Hard Drive Replacement!?
Hi there,
I used my WD Elements 2TB drive for about a year when it stopped working.
So I RMA’d the drive 2 weeks ago and today I got the replacement drive delivered.
When I openened the package I could see it was not a WD Elements 2TB drive.
It was a MyBook 3TB USB3.0 instead.
Has something gone wrong at WD or was it meant to be a better (more expensive) drive?
Should I contact them or should I just keep this better drive?
Thanks for your reply.
Sometimes when WD does not have the original drive in stock they sent you better model, perhaps that’s your case. I guess is better if you contact WD to investigate.
