Reply
Occasional Advisor
arivghosh
0
WD SES Device USB Device
Hi,I have a 1tb wd my book,it was working properly for the last 1 year but today voltage fluctuation took place and now i can see its connected to the PC but i can't access it,it's hidden somewhere in my computer and the same "wd ses device" problem is there in the device manager but i cant use smartware since i cant locate my external drive in my computer......HELP ME OUT PLEASE...i dont want to replace it bcoz i have some important documents in it which i dont wanna lose at any cost
Honored Contributor
ThePizzaMatrix
0
Re: WD SES Device USB Device
Hi there, you can get the SES drivers from here, just download the file for your OS (32 or 64 bit), right-click the SES device on device manager and select update driver, the search for the SES.
If the drive is still not seen after reloading the drivers, then check if the drive is on disk management (Right-click on computer/my computer> manage> disk management) and see if the drive is there without a letter, or raw, or healthy or unallocated.
You are reading a ghost long gone.
Occasional Advisor
arivghosh
0
Occasional Advisor
arivghosh
0
yup the harddrive is without a name,healthy n there is a blank in  file system ....i have posted a pic of my disk management also.....i have installed ses driver but still not worthy of it....what should i do? HELP ME
Occasional Advisor
arivghosh
0
[ Edited ]
The first two are the drives of my external harddrive
Honored Contributor
ThePizzaMatrix
0
Dude, the drive has lost the file system, you'll need to do data recovery....
Try TestDisk, it is free and has helped a lot of users in here....
Occasional Advisor
arivghosh
0
wher can I find TEST DISK?Can you please send me the link...
Honored Contributor
ThePizzaMatrix
0
Quick Google search: The very first link, here you go.
http://www.cgsecurity.org/wiki/TestDisk
