Reply
Occasional Visitor
0
WD P/N WD6400H1U-00 Power Loss
I have had my WD (My Book) external drive for a couple of years and have not had any problems with it. The day i decided to back it up on another drive it stopped working altogether. The power pack indicator is working but the box is not turning powering up. is there a way to save all my data from off of this?
Honored Contributor
0
Re: WD P/N WD6400H1U-00 Power Loss
If not showing on the computer only other way is removing from enclosure ( voids warranty ) and connecting to a PC direct
you can try with a data recovery specialist as well
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
