I am connecting a My Book 3.0tb USB 3.0 to a PC running Windows 8.1. First Question: My music library is located on an external HD and is has been added to the My Music library on the PC. If I use the WD SmartWare for continuous backups, will the external music library be backed up along with my personal data on C:?
Second Question: If the answer to the above is no, can I use Smartware to continuously back up C:\ and then back up the external HD to the same My Book using copy and paste? If yes, do I need to create a separate partition for the external HD folder and how do I go about it.
Thanks for the help.
grapeman
