Reply
Frequent Visitor
Milkyway
0
Slow write speed on My Book Essential 3TB
I just got a My Book Essential 3TB and my laptop is Dell precision M6500 which has usb 3.0 ports. When I test the hard drive, I find the write speed only goes up 55 M/s. Anyone know the reasons? The laptop uses NEC chipset.
Honored Contributor
Joe_S
0
Re: Slow write speed on My Book Essential 3TB
[ Edited ]
How fast is the HD in the laptop? If it'a slower 5400 rpm drive that will impact the write speed. Go into Device Manager find the external drive right click and properties then on Policies tab change to better performance reboot and see if it makes any difference.
Joe
Click the Kudos star to say thank you for helpful posts. And be sure to come back to click the 'Accept as Solution' button for the post that solved your issue.
Frequent Visitor
Milkyway
0
Thanks Joe, I changed the policies tag to better performance, it gave me the same speed. The first image was I tested again on Mybook 3TB and the second one is my laptop;s HD. There are 2 x 500G 7200 RPM (Seagate 7200.4 )  HD in my laptop and I am using RAID 0.
Frequent Visitor
Milkyway
0
Need ur help. And  is there any one knows WD's contact phone number in UK?Capture.PNG
Honored Contributor
Joe_S
0
Try this http://support.wdc.com/contact/index.asp?wdc_lang=en#europe
Joe
Frequent Visitor
Milkyway
0
Sorry , tried those number before, none of them work. For every country in Europe, the phone number is same.
00800-ASK4WDEU
(00800- 27549338)
Can you tell me how to dial it?
