What do I need to do to get a new iMac to recognize/use my PC (XP) Anywhere Backup (Version 3.00.3112)? Would like to use it to transfer my PC files to the new iMac.
Then, can I use my WD Anywhere Backup to backup my iMac?
You can also follow the links below for the instructions on how to format your drive to make it compatible with Windows and Mac’s and then use Anywhere backup to backup your files. Note that formatting your hard drive will delete all the files.
How to format a WD external hard drive in exFAT or FAT32 (to use in Windows or Mac OSX)
