Help help help
My daughter knocked over my Hard Drive, and knocked off the (i think) micro b/usb cord input and broke the housing. So know I can’t acces my hard drive at all. Is there any way i can get it put back on or any other way to acces my files on it???
A dropped drive is often physically damaged and beyond do it yourself recovery. Professional data recovery might salvage some of the data. You might try finding an electronics repair place and have them solder a port back on. I wouldn’t count on having much sucess if that does work.
Joe
