4TB WD My Book WDBFJK0040HBK-NESN ***HELP***
Is this true that I cannot use this specific drive (4TB WD My Book WDBFJK0040HBK-NESN) to store content and send to my television through a WD Media Player Model: WDBYMN0000NBK-HESN?   Customer Review from Newegg.com for the 4TB WD My Book WDBFJK0040HBK-NESN says, Cons: Caution! this is not the same product as WD Mybook live. WD no longer makes the Mybook live, which was a NAS devise. This Mybook is a direct connect device not capable of being an NAS or acting as a media storage/server for a network.   If true, what should I purchase as I won’t have this always attached to my PC?
You can use this drive with the media player if you connect it through USB. If you are looking for a NAS drive then I recommend you take a look at the WD My Cloud.
