My passport ultra problems using it on Mac book pro
I have connected the WD drive and all thats happened is a short cut on the desk top, and in finder passport is listed under devices on the left.
however if I try and put a file in it from my computer or from drop box it asks for a authenticity password ? but no password will work so i cannot do anything with the drive.
No software has appeared since I first tried to install it either.
Please help
This drive comes formatted NTFS for Windows use, If you want to use it on a Mac you will need to format it for Mac.
How to partition and format a WD drive on Windows (8, 7, Vista, XP) and Mac OSX
