Lost USB Cable need a replacement
Can anyone help?
I’ve lost the USB cable for the above drive. I need a new one. Can you tell me what type of cable it is and where I can get a replacement?
Is it a micro usb to usb?
The drive was bought on the 14/12/2009 and is therefore old. It is USB 2. Unlike your current drives it’s cable is different.
It’s serial number is: WU2O or it could be Q [Deleted]
Cheers,
ATT
Hi and welcome to the WD Community. The model number you are sharing is not a correct one, but if you bought it in 2009 it is most provably a USB Mini cable. Looking at a picture you can also see the different shape of the cables.
Thanks Jubel04,
That certainly look like the right one. Mini instead of micro.
Your help is greatly appreciarted.
ATT
