I’ve had a wd drive for about a year now, and only used it to store music/ pictures/ videos & stuff.
Before, it would only start spinning up when i wanted to use a file stored on the drive, but now it’s starting up whenever it feels like it. Browsing the net will set it off constantly, forcing the webpage/youtube vid to freeze till it’s finished booting up, and even with no programs running it’ll turn on and off whenever it pleases.
I don’t know if I accidently messed up something in the bios, or if I have a virus or what.
Any help would be appreciated.
Also youtube vids are loading super slow now, not sure what’s up with that, but anything past 240p will buffer every 3 seconds.
Be sure that no program is running in the background that might be using the hard drive. To know if your hard drive has any hardware problems, you can try doing a DLG test. Check the link below for the steps.
