Using a drive as a singel drive (WD Green or Red?)
I’vre red that some people goes against using a WD Red as a singel drive, is that true? The bad thing with the Green variant is it’s using four platters and louder than the Red version which only uses 3 platters and are quieter.
Don’t see why not, they are mainly advertised as NAS HDDs but they can also be used as single drives.
Use the red drives for 24/7 NAS operation… Don’t use green drives… They should only be used as backup/secondary on pcs… Not as main drives…
