Unable to find correct information to set WD3200AAKX WD CAVIAR BLUE as slave on desktop with windows xp OP sys. I have looked through WDC’s support info but unable to find a solution to my issue.
Hi gjheath,
The WD3200AAKX is a SATA drive. SATA drives do not use jumpers for this purpose, they don’t follow a ‘master’ and ‘slave’ hierarchy like older EIDE drives do since each drive has it’s own cable.
