Incorrect SMART Power On Hours (RE3 1TB)
I have three 1TB RE3 (WDC WD1002FBYS-01A6B0) and three 160GB RE1 (WDC WD1600YS-01SHB1) installed in my local servers. Every HDD should have a power on time of at least one year now, though SMART reports 66 hours for every RE3, while its close to three years for my old RE1s.
Why doesn’t it keep properly track of its total power on time?
Here is a sample log of one of my RE3:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   047    -    0
  3 Spin_Up_Time            bleep --K   253   253   039    -    1233
  4 Start_Stop_Count        -O–CK   098   098   050    -    2411
  5 Reallocated_Sector_Ct   PO–CK   200   200   051    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   046    -    0
  9 Power_On_Hours          -O–CK   100   100   050    -    66
 10 Spin_Retry_Count        -O–CK   100   100   050    -    0
 11 Calibration_Retry_Count -O–CK   100   100   050    -    0
 12 Power_Cycle_Count       -O–CK   098   098   050    -    2368
192 Power-Off_Retract_Count -O–CK   200   200   050    -    480
193 Load_Cycle_Count        -O–CK   200   200   050    -    2405
194 Temperature_Celsius     -O—K   111   090   034    -    39
196 Reallocated_Event_Count -O–CK   200   200   050    -    0
197 Current_Pending_Sector  -O–CK   200   200   050    -    0
198 Offline_Uncorrectable   ----CK   200   200   048    -    0
199 UDMA_CRC_Error_Count    -O–CK   200   200   050    -    0
200 Multi_Zone_Error_Rate   —R--   200   200   008    -    0
                            ||||||_ K auto-keep
                            ||||| C event count
_ R error rate
                            ||| S speed/performance
_ O updated online
                            | ______ P prefailure warning
And here’s a RE1 smartlog:
  1 Raw_Read_Error_Rate     POSR--   200   200   015    -    0
  3 Spin_Up_Time            PO----   183   028   003    -    3808
  4 Start_Stop_Count        -O–CK   096   096   050    -    4466
  7 Seek_Error_Rate         POSR--   200   200   015    -    0
  9 Power_On_Hours          -O–CK   065   065   050    -    25901
 10 Spin_Retry_Count        PO–C-   100   100   019    -    0
 11 Calibration_Retry_Count PO–C-   100   100   019    -    0
 12 Power_Cycle_Count       -O–CK   098   098   050    -    2617
194 Temperature_Celsius     -O—K   120   086   034    -    27
197 Current_Pending_Sector  -O–C-   200   200   018    -    0
198 Offline_Uncorrectable   ----C-   200   200   016    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   062    -    1
200 Multi_Zone_Error_Rate   P–R--   200   200   009    -    0
                            ||||||_ K auto-keep
                            ||||| C event count
_ R error rate
_ O updated online
Try getting a second opinion with hd tune or other application
I already did. I used smartmontools and aida64. Same result. I doubt the software is the issue.
Also, I tried this with two different mainboards (Asus P8P67 Deluxe rev2.0 and Gigabyte GA-P35C-DS3R). Same result here as well.
Anyone running the same HDD as me, could you check your smart values as well and post them here? Since I got three drives with the identical issue, it might be an issue with the whole RE3 1TB series.
Edit: Just like I thought… it certainly is counting the hours, but its loosing those from time to time. log of the same RE3 1TB from above, just one day later:
  9 Power_On_Hours          -O–CK   100   100   050    -    88
194 Temperature_Celsius     -O—K   112   090   034    -    38
                            ||||||_ K auto-keep
                            ||||| C event count
_ R error rate
_ O updated online
