I’m building up RAID6 on Openmediavault right now. During the resync process there where similar S.M.A.R.T. error messages:
After the resync i checked all my drives and here is one drive as an example:
=== START OF INFORMATION SECTION ===
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCCXXXXXX
LU WWN Device Id: 5 0014ee 2b4dab5a0
Firmware Version: 80.00A80
User Capacity: 4.000.787.030.016 bytes [4,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 9
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Wed Jul 30 16:43:41 2014 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (52380) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 186 186 021 Pre-fail Always - 7683
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 9
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 117
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 9
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 8
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 23
194 Temperature_Celsius 0x0022 118 109 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 4
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 4 occurred at disk power-on lifetime: 96 hours (4 days + 0 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 51 01 00 00 00 00 Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 d5 01 e1 4f c2 00 00 02:22:10.072 SMART READ LOG
b0 d6 01 e0 4f c2 00 00 02:22:10.071 SMART WRITE LOG
b0 d6 01 e0 4f c2 00 00 02:22:10.070 SMART WRITE LOG
Error 3 occurred at disk power-on lifetime: 96 hours (4 days + 0 hours)
b0 d6 01 e0 4f c2 00 00 02:22:10.069 SMART WRITE LOG
Error 2 occurred at disk power-on lifetime: 44 hours (1 days + 20 hours)
b0 d5 01 e1 4f c2 00 00 01:02:08.970 SMART READ LOG
b0 d5 01 e1 4f c2 00 00 01:02:08.969 SMART READ LOG
b0 d6 01 e0 4f c2 00 00 01:02:08.968 SMART WRITE LOG
Error 1 occurred at disk power-on lifetime: 44 hours (1 days + 20 hours)
b0 d6 01 e0 4f c2 00 00 01:02:08.967 SMART WRITE LOG
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 117 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Are these errors “real” errors and the drive dies? I can’t believe that all of my drives are sh**?! On the other hand fhe S.M.A.R.T. values are looking good so far…
And all drives are not older than 6 months!
What’s wrong here?
And what is the Airflow_temperature_cel ? The temperature of my drive is under 45 °C but it’s posting such messages the whole time (look at the first pic)
greets
