hello, 1st time post at here, i have a problem, my WD caviar green cannot run anymore, every time i plug in power, just the PCB will feel hot, then nothing else will happen… does replace a new PCB will help? i need the data inside my HDD. pls help >.<
Hi, replacing the PCB board can be complicated sometimes. Not only the model number for the PCB must match but also the firmware version. You can also contact a data recovery company.
