djpirra wrote:
What? Are you for real? Optical does not allow TrueHD? **bleep**! I will check that info tonight! Wicked, i really thought optical was better. Thanks
No problem, just Google “optical HD audio” and you’ll find a bunch of info.
Just to add to my previous comment, the limiting factor associated with Optical cables is the S/PDIF specification that pretty much all consumer audio equipment adheres to. The physical cable could, in theory, send HD audio as it has a bandwidth up to 125Mbps. The S/PDIF spec limits bandwidth to only 1.5Mbps, crippling performance.
It seems that i have to switch my PS3 to an HDMI port on TV and use the Live Hub HDMI to connect to my Audio Decoder since it only have 2 HDMI Ports and one is for cable TV already ( I wish it had 3… ).
I dont remember the home theater model but the player/decoder is a bd-c6900 yes. The files are in mkv and none of them that have DDTrueHD seems to send audio. Only Dolby Digital or DTS MA…
You need to explain what you are plugging the HDMI out from the WDTV into.
However if you you are trying to use the network playback features of the BD-C6900 then that is a totally different question. Samsung devices are well-known for not supporting many (actually most) media codecs/formats with network playback.
*Did you unplug your optical cable? Is the Hub set to output via HDMI only? The only circumstances I can think of that would stop DDTrueHD working is if your amp still thinks it should be playing audio via optical or the files themselves are incorrectly encoded. As requested earlier in the thread, post the MediaInfo output for one of your non-working files and well take a look. Google MediaInfo, it’s a free app, very useful.
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Muxing mode : Header stripping
Codec ID : A_DTS
Duration : 2h 23mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.51 GiB (8%)
Language : English
Audio #2
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 2h 23mn
Bit rate mode : Variable
Maximum bit rate : 5 445 Kbps
Compression mode : Lossless
Language : English
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : English
Here it is another mediainfo for another file that does not reproduce sound:
General
Unique ID : 236834746272838303029819335511529327818 (0xB22CB685523F46899C61D56100458CCA)
Complete name : [\WDTVLiveHub\WDTVLiveHub\3D\XXXXX_3D.mkv](file://%5C%5CWDTVLiveHub%5CWDTVLiveHub%5C3D%5CHOW_TO_TRAIN_YOUR_DRAGON_3D.mkv)
Format : Matroska
File size : 9.03 GiB
Duration : 1h 37mn
Overall bit rate : 13.2 Mbps
Movie name : XXXXX.3D.Bluray3DRip
Encoded date : UTC 2010-11-17 00:54:09
Writing application : DVDFab
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 37mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1h 37mn
Maximum bit rate : 5 049 Kbps
Channel(s) : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Language : English
Nothing jumps out as being wrong in either of those MediaInfo outputs.
In your first file, I thought perhaps that it had Header Compression enabled (which shouldn’t be an issue) but to try remuxing it anyway.
Yet the 2nd file doesn’t appear to have that and still doesn’t work.
I really don’t know what to suggest; all I can say is that the DDTrueHD files I have output as DDTrueHD and play fine on my Hub.
Not sure where you’re getting your files from (apologies if you encoded them yourself) but the most likely culprit is incorrect encoding. Try remuxing with MKVmerge, just to rule that out.
Something else to try is downloading the same files I’m testing with.
Go here and grab some DDTrueHD files from the Dolby section:
