LOL - The fact I did not post in the ideas exchange, although I recall I did post there??? Is because my concerns have already been raised. The GO-TO function, menu support, etc…There are a few new features I came up with and yes I will post them, but I recall they have been addressed too (picture position, bad cropping, etc.)
I KNOW this is a piece of consumer equipment, and I disagree about the cheap made in china - I have quite a lot of units made in China and they are well built, considering their price. I mentioned on several occasions my Toshiba SD3990 player, which I purchased for nearly half the price of the WD Live, ok it does not play all formats, BUT if I compare the quality of the outputs, with the SAME mpeg files and AVI, yes it does support MPEG1/2/AVI, it’s like day and night ! Also the upconvert quality is by far superior! So either WD is not doing their job in properly programming the sigma chip, OR…perhaps the onboard SMP is not all cut out to be - but there again, this family of chipset can also be found in other players, set top boxes, DVRs, too.
As to DVD Menu, yes it would be a GREAT feature to have - they could have licensed and added an extra chip for DVD, but the cost of the unit would have gone up ! The reason they play those VOBs is because they are trated like MPEG files, essentially, and would only work on non multi angle based VOBs.
I will not hold a grduge against WD if they don’t add DVD menu support eventhough initially, when I read that it supports VIDEO_TS / VOB , thought it had built support for menu… With DVDs with multi titles, you can use a tool like VOBEDIT and “extract” individual MPEG streams from each title set - rename files accordingly afterwards.
Playback of a crisp, clean MPEG-2 file from a Toshiba SD3990, composite out = very clean, razor sharp.
Playing back of the SAME file through the WD Live, the result is the image appears over cropped / scaled larger than the overscan area, and it appears significantly softer. Yes it is an interlaced MPEG-2 720x480, and YES I checked the appropriate options !
You see ? I am comparing 2 very basic, consumer pieces of euipment with the same playback file.
I haven’t opened my Toshiba SD3990 yet, I am not aware what chipset lies inside, perhaps a Zoran ? not sure, but the quality output of the same MPEG2/VOBs are so different.
Oddly, I don’t see this softening effect when playing back quicktime & WMV throught he lWD Live, whether they are SD or HD …
