Community Manager Bill_S: Your assertion that this family of drives can be used without installing Smartware is simply not consistent with my experience, and with the experience of a number of others who have posted to this forum their Smartware woes.
As I’ve described in earlier posts, after giving-up on using Smartware, I not only uninstalled Smartware, I used JV16 to remove ALL TRACES of Smartware from the registry and hard drives, then formatted the MyBook HDD while it was plugged into a completely different machine. Plugging the drive back into the original desktop computer after a reboot, Windows couldn’t see the MyBook, and couldn’t find a suitable driver. Several more reboots and it found the VCD in the MSfot driver library and I let that install. To my surprise, after another reboot the Smartware apps were back in the Windows services list, set to “manual.” The driver for the MyBook/Passport and Smartware are inseparable!
I’m sorry, but I believe your assertion is not correct. And, more, it belies the problem that Smartware changes the filenames being actually saved to the MyBook, which requires the Smartware file management interpreter to be running to un-interpret those names whenever any process accesses the MyBook to lookup, report, get or put a file! Whatever device the MyBook/Passport is attached to, Smartware MUST be installed for this to happen, and to give the device a driver to even be able to see the MyBook/Passport. It’s not a Windows application or quirk changing the file names. It’s Smartware.
Most users of this WD backup drive family won’t see this renaming, because it is masked by the interpreter that is part of the “required” Smartware install. They’ll only see and experience the horrendous problems that Smartware brings. But use an app designed to go directly to the file tables for the MyBook in order to recover files directly, you will probably get your files back, but they are NOT going to be named what you expected them to be named, and you are going to pay a price in frustration, time and effort to return them to the state they were in before Smartware renamed them.
