I am having the same problem also.
Is there a possibility of useing βdisk utilityβ on my iMac to change the drives to JBOD ? By passing the unworkable software that comes with this External Drive.
I was able to create a mirrored RAID using disk utilityβ¦ For what itβs work. I was surprised how easy it was.
For what itβs worth, todayβs update fixed the WD utility for 10.8.5.
I can confirm that the update to WD Drive Utilities now works with 10.8.5. Β I am still getting the disconnect drive error when coming back from sleep, but I think thats a Apple issue they are planning to address.
Western Digital just released a new version of their Drive Utilities for Mac.Β Version 1.1.7.5 should resolve your issue of drive not seen
I am reaching out to you today because of your recent issue of WD Drive Utilities for Mac not properly recognizing your My Book Thunderbolt Duo.Β Western Digital has just released version 1.1.7.5 to resolve this particular issue.
Please follow the link below to download and install this new version of drive utility.
Apple just released the OS X 10.8.5 Supplemental Update that fixes my problem with the Duo disconnecting when coming back from sleep. Β http://support.apple.com/kb/DL1686
Everytthing is back working like normal again with the WD Utilities and Apples update.
Bradley
bdavidson wrote:
Apple just released the OS X 10.8.5 Supplemental Update that fixes my problem with the Duo disconnecting when coming back from sleep. http://support.apple.com/kb/DL1686
Bradley
Thanks for posting this information.
Other users should try this update and report back if the issue has been solved
Update:
This issue can be solved by downloading the latest version of WD Quick Utilities.
