Thanks Joey
I will try it out this afternoon!!!
Thanks Joey
Joey,
Couple of things but before I start I just LOVE this theme, it looks the biz
However firstly the lip sync option is not availble with this theme, no biggy just noticed it yesterday
Other thing is & not sure if it this theme or the SMP but I have a portable hard drive attached to the rear usb & drop films off the PC onto the drive on a regular basis.
I have get content info selected as auto & presumed each new film would get this each time but it doesn’t
I have to either manually select to obtain this or reset the SMP
Is this correct, I mean should it be like this
Whenever I remove the hard drive & add films then reconnect it gets content info automatically
Lee
welly1962 wrote: However firstly the lip sync option is not availble with this theme
Yes it is. Try scrolling down. (the view is unfinished, which is why it looks untidy)
For all your other issues, a theme cannot cause that behaviour. (a ‘theme’ is a skin, it just changes the visual appearance … not the internal functions of the WDTV)
Whenever you have an “issue” with your WDTV, always revert back to either of the WD Default themes… Grid or Mochi, that way, you can isolate whether it’s a ‘theme’ problem or a ‘WDTV’ problem.
Thanks Joey, will have a proper look later
regarding the get content issue am I right in thinking that it should grab the data automatically if set to auto once a movie has been added to the usb drive either by network or drag & drop or does the drive need to be removed each time?
The WD manual doesn’t make it clear
small update …
added the missing text icons for AOL.On and WD MyCloud app which were introduced into Firmware 1.02.17
Added a User requested Gallery View Modification ( download links on Page[1] )
Many thanks and kudos to Joey for his patience and assistance in getting the theme up and working in its moded form for me.
Hopefully, Joey may eventually find some time to finish the music views etc to round out this great theme.
in time, got a lot on my plate at the moment
hi Joey, Awesome theme mate.
Know you are busy but if you get a chance could you add the Welo Gallery view to this theme. I have tried but the main menu went awol and reverted back to mochi standard. Cheers
if you did a complete copy’n’paste … then that’s why the Main Menu went screwy
the xml file in question is meta.xml … don’t replace or modify that xml in PM4 WD
but, still, after that’s sorted … there is a lot of time required to modify the “welo gallery” to fit (aesthetically) within the theme
time i don’t have unfortunately (due to health issues)
Joey
I am new member to the site as far as posting goes. I have and simply love this theme. I noticed in screen shot 4 where you have the 4 screen shots of the movie. Is this something that the smp will do? Before I was generating them through thumbgens. Is there a template for that look?
Thanks and it is a wonderful job you have done.
Bob
hello
this is a really cool theme i really wat to be able to use it on my hub.is there a home menu for the HUB yet
many thanks
Thanks, for this great theme. I’m trying to add the Flixster scores to the wide gallery page, but it’s not showing. I just changed rv_gallery_browse_page.xml, moved some of the text to the left in the Time/Genre line and copied the Flixster part from another page. The star character appears in the correct place, but nothing else does. Is there anything else I should do to make this work? Thanks!
My changes (first three lines were there, just changed x coordinates). The rest is added.
<text x="500" y="517" w="300" h="20" text="@@genre" fontsize="18" textcolor="0xaaaaaa" align="left" />
<text x="300" y="517" w="200" h="20" text="@@year" fontsize="18" textcolor="0xaaaaaa" align="left"/>
<text x="100" y="517" w="200" h="20" text="@@totaltime" fontsize="18" textcolor="0xaaaaaa" align="left"/>
<wrapper w="24" h="22" x="800" y="517" scale="100">
<text text="*" fontsize="18"/>
<image image="@@flixster_critic_icon_0" /> <image image="@@flixster_critic_icon_1" /> <image image="@@flixster_critic_icon_2" /> <image image="@@flixster_critic_icon_3" /> <image image="@@flixster_critic_icon_4" /> <image image="@@flixster_critic_icon_5" /> <image image="@@flixster_critic_icon_6" />
</wrapper>
<wrapper w="50" h="22" x="831" y="517" fontsize="18" align="left" textcolor="0xdddddd"> <text text="@@flixster_critic_score_0" /> <text text="@@flixster_critic_score_1" /> <text text="@@flixster_critic_score_2" /> <text text="@@flixster_critic_score_3" /> <text text="@@flixster_critic_score_4" /> <text text="@@flixster_critic_score_5" /> <text text="@@flixster_critic_score_6" />
</wrapper>
<wrapper w="20" h="22" x="879" y="517" scale="100"> <image image="@@flixster_audience_icon_0" /> <image image="@@flixster_audience_icon_1" /> <image image="@@flixster_audience_icon_2" /> <image image="@@flixster_audience_icon_3" /> <image image="@@flixster_audience_icon_4" /> <image image="@@flixster_audience_icon_5" /> <image image="@@flixster_audience_icon_6" />
</wrapper>
<wrapper w="50" h="22" x="907" y="517" fontsize="18" align="left" textcolor="0xdddddd"> <text text="@@flixster_audience_score_0" /> <text text="@@flixster_audience_score_1" /> <text text="@@flixster_audience_score_2" /> <text text="@@flixster_audience_score_3" /> <text text="@@flixster_audience_score_4" /> <text text="@@flixster_audience_score_5" /> <text text="@@flixster_audience_score_6" />
</wrapper>
