I am having the same freezing issues from my NAS, even movies that were ok in the past.
user08152 wrote:
thatās what I used actuallyā¦hmā¦
I created a new mkv straight from mkvMergeGUIā¦with aforementioned resultsā¦maybe I should try your 2-step-process?!
Im using mkvmerge as u suggested and so far so good, can rename and move files, and they work on wdtv (so far!)
its not a codec issue your having is it? as i had similar issues until i uninstalled the diivx codec pack - just a thought.
Iāve reported this issue a 3 weeks ago. The issue is with the SMP and encoded files using Handbrake 0.9.6 or Vidcoder. The encoded files play fine on the WDTV Live & WDTV Live Plus. I donāt have any problems if I encode using Handbrake version 0.9.5.
http://community.wdc.com/t5/WD-TV-Live-Streaming-Issue/MKV-files-Freeze-SMP/idi-p/370725
heheā¦advanced video voodoo
uninstalled the divX codec pack and now Iām also able to rename and delete the filesā¦thanks!
(thumbnails are still gone, also no more mkv playback in Windows media playerā¦you just canāt have everything it seemsā¦ :-/
vlc all the way!!
so going forward I am going to use the previous version of handbrake to encode my rips, that should mean I dont need to remux, and Iām not going to update firmware on wdtv until reading these forums, especially not for an MLB updateā¦
This is an issue Iāve encountered a few times with different files as well - MKVās freezing at the same spot in playback.Ā Iāve trawled through google looking for solutions (as none sem to have been presented by WD staff - consumers whoāve purchased the product have essentially turned int WDās de facto R&D team it seems - posting results and workarounds on this site.Ā Whereās my paycheck!!??).Ā
Just this morning I thought Iād try yet again to see if I could identify and rectify the problem by re-encoding with different settings and testing - a tme consuming process!Ā I recalled reading somewhere that using the front port on the media player might be a solution (despite the fact theat the cord is visible making the setup less visually appealing).Ā Yesterday I reset the player to factory defaults (I assume this resets the firmware to default too).
Up until the time of writing Iāve tried 7 different encodes of exactly the same file using various settings.Ā With the external WD 1TB portable HDD plugged into the FRONT PORT there have been no playback issues at all.
Iāll attempt once Iāve completed this painful experiment, to let you know if the rear port has issues with playback of the same files.Ā
Hope this helps.
mooster wrote:
This is an issue Iāve encountered a few times with different files as well - MKVās freezing at the same spot in playback. Iāve trawled through google looking for solutions (as none sem to have been presented by WD staff - consumers whoāve purchased the product have essentially turned int WDās de facto R&D team it seems - posting results and workarounds on this site. Whereās my paycheck!!??).
Just this morning I thought Iād try yet again to see if I could identify and rectify the problem by re-encoding with different settings and testing - a tme consuming process! I recalled reading somewhere that using the front port on the media player might be a solution (despite the fact theat the cord is visible making the setup less visually appealing). Yesterday I reset the player to factory defaults (I assume this resets the firmware to default too).
Up until the time of writing Iāve tried 7 different encodes of exactly the same file using various settings. With the external WD 1TB portable HDD plugged into the FRONT PORT there have been no playback issues at all.
Hope this helps.
Please describe: What model P/N is located at the bottom of your device?
I do suspect that may be a difference between models ending with ā01ā and ā00ā(revision ā01ā and ā00ā).
This issue described in details here:
http://community.wdc.com/t5/WD-TV-Live-Streaming-Discussions/Intention-to-finalize-a-rear-USB-port-issue-drives-USB-3-0/m-p/392589/highlight/true#M7913
This may help to accelerate it solution.
PN ends in 01 - hope this is helpful.Ā
The method described above (plugging into the front port) is still proving effective - no freezing of playback for any of the previously problematic files.Ā I still havenāt bothered upgrading the firmware again either in case it sends things screwy.
I read about this particular player somewhere else, that the usb cable āappearsā to not be fully inserted even when it can be pushed no further.Ā This is the case for my unit as well.Ā Is it going to be possible to fix the issues that the rear port is clearly having with a firmware upgrade?
To the best of my knowledge the WD external, portable 1Tb HDD Iām playing from is USB 2.
