On my hub, I have to power it completely off (press and hold the on/off remote button for 5-8 seconds), wait 30 seconds or so, then power the hub back on. If that doesn’t work, try turning the library off, then clear the library, then do the power cycle thing just mentioned, then once the hub is back up, turn library back on and let it recompile it from scratch.
