i didnt knew that there is connectivery problem now
and i downgraded my My cloud device
and now i have flat page with no options to upgrade it
can i update it throug the SSH?
i have used this to downgrade:
Thanks a lot!
Your instructions worked flawlessly (even though I used SSH).
4.00.00-607 was truly a dud (for me, your mileage may vary of course) and now I finally have my nice old NAS back again…
Thanks again!
please help !!!
solved the problem with 40sec reset butten preesd while the mycloud is off
You can use SSH to change your unit’s firmware. However, such proceedings are not warranted or supported by Western Digital. I’d recommend verifying if your particular case has been addressed in the thread you have shared.
i’ve been able to resolve the problem with the “40 sec” restore
when I understood that the problem is with WD, I’ve upgraded the firmware back to the latest version and now it’s ruuning almost ok
