Herokolco wrote:> The only thing that confused me that I can’t see the download folder TR-Downloads in /DataVolume/shares/Public If I understand correctly incomplete torrent files are temporarilystored in /root/DataVolume/shares/Public/TR-Downloads When the file has finished downloading it is finally moved to /DataVolume/shares/Public/TR-Downloads
Thanks for great guide!
I edited the json file so downloads in progress go to Public/TR-INCOMPLETE
Once completed it get’s moved to Public/TR-Downloads
You need to stop Transmission, delete the json file, and create a new json file
/etc/init.d/transmission-daemon stoprm /root/.config/transmission-daemon/settings.jsonnano /root/.config/transmission-daemon/settings.json
Copy the new json text below and paste it into your nano window
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://www.bluetack.co.uk/config/level1.gz",
"cache-size-mb": 4,
"dht-enabled": true,
"download-dir": "/DataVolume/shares/Public/TR-Downloads",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/DataVolume/shares/Public/TR-INCOMPLETE",
"incomplete-dir-enabled": true,
"lpd-enabled": false,
"message-level": 2,
"peer-congestion-algorithm": "",
"peer-limit-global": 240,
"peer-limit-per-torrent": 60,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": false,
"preallocation": 1,
"prefetch-enabled": 1,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{5d73272dade2dccb326e823e555a8bccd6c235f2SkqI2LBJ",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "",
"rpc-whitelist": "127.0.0.1",
"rpc-whitelist-enabled": false,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": true
Hit control and o
Hit enter
Hit control and x
This will save your edited file
Change json permissions
chmod 600 /root/.config/transmission-daemon/settings.json
Restart Transmission
/etc/init.d/transmission-daemon start
As soon as you start a download it should create Public/TR-INCOMPLETE
Once the download has finished it should create Public/TR-Downloads and move the completed file there
Works perfect here
