Is that the same as jdownloader?
I’m not sure.
most important is the installation routine for me.
Frank
Can you link me to the program?
or
#!/opt/bin
curl "http://fritz.box:49000/upnp/control/WANIPConn1" -H "Content-Type: text/xml; charset="utf-8"" -H "SoapAction:urn:schemas-upnp-org:service:WANIPConnection:1#ForceTermination" -d "
<?xml version='1.0' encoding='utf-8'?>
<s:Envelope s:encodingStyle='http://schemas.xmlsoap.org/soap/encoding/' xmlns:s='http://schemas.xmlsoap.org/soap/envelope/'>
<s:Body> <u:ForceTermination xmlns:u='urn:schemas-upnp-org:service:WANIPConnection:1' />
</s:Body> </s:Envelope>"
I dont know…
Frank
hi can i install it on fw 02.42.03???<
Yes
when i tap the ip:8000 it didnt show the webinterface and now i see in the picture that it says pyqt4 is missing
what can i do ???
thnx
pyqt4 is not needed, continue with the setup
If you have completed the guide and the interface still doesn’t come up type
/etc/init.d/pyload restart
And try the web interface again
still nothing
can you please guide me from the begging to fix it??
thnx
I would love to but I’m not sure where you went wrong. The best I can do is suggest you follow the guide again from the beginning
if i install it from the bigging they havent problem like to brick??
nope
what have to to do in the following?? just to copy the first line,enter ,second line ,enter???
issue the following commands to ensure that we can use the command “ipkg” from any directory
echo "export PATH=$PATH:/opt/bin:/opt/sbin" >> /root/.bashrc
echo "export PATH=$PATH:/opt/bin:/opt/sbin" >> /etc/profile
yes
the same as before copy and enter ???
in the previously post with two lines is anything happend when press enter
Edit HTTPRequest.py so pyLoad setup will run
nano /opt/share/pyload/module/network/HTTPRequest.py
thank u my friend at last i did it but i think that the plugins didnt updated at all
why???
thnx
hi if i do reset from behind the mbl the pyload and transimission would be deleted??
thnx
ok i did a reset and everything is ok but when i stop a dl and then a press start the dl dont start everything stays in queue why??
thnx
