Maybe thats why my DroboPro is off line and stuck in a loop. I have an early 2008 Mac Pro and tried Mavericks on one drive but it froze and even booting into Safe mode didn’t help, I thought it was PGP software even though the disk wasn’t incrypted.
Interestingly when I tried to reboot from another drive bay holding a partitioned WD Drive. It had also been damaged.
WDC WD20EARS-00J2GB0:
Capacity:2 TB (2,000,398,934,016 bytes)
Model:WDC WD20EARS-00J2GB0
Revision:80.00A80
Serial Number: [Deleted]
Native Command Queuing:Yes
Queue Depth:32
Removable Media:No
Detachable Drive:No
BSD Name:disk3
Medium Type:Rotational
Bay Name:Bay 3
Partition Map Type:GPT (GUID Partition Table)
S.M.A.R.T. status:Verified
Volumes:
disk3s1:
Capacity:209.7 MB (209,715,200 bytes)
BSD Name:disk3s1
Content:EFI
Media 2:
Capacity:1.4 TB (1,397,039,304,704 bytes)
Available:1.39 TB (1,386,731,048,960 bytes)
Writable:Yes
File System:Journaled HFS+
BSD Name:disk3s2
Mount Point:/Volumes/Media 2
Content:Apple_HFS
Volume UUID:23C2479A-07DE-3C89-8C05-F6317E246C32
Velociraptor Clone:
Capacity:602.23 GB (602,231,435,264 bytes)
Available:187.56 GB (187,559,440,384 bytes)
Writable:Yes
BSD Name:disk3s3
Mount Point:/
Content:Apple_HFS
Volume UUID:B1882A11-520F-3804-A2BB-889E07DD2D87
Recovery HD:
Capacity:650 MB (650,002,432 bytes)
BSD Name:disk3s4
Content:Apple_Boot
Volume UUID:41E30072-4851-36AD-BD09-C8AAAD78D404
Not being able to boot reliable off that damaged partition I rebooted from a firewire connected partitioned MyBook
FireWire Bus:
Maximum Speed:Up to 800 Mb/sec
My Book:
Manufacturer:WD
Model:0x1105
GUID:0x90A99500A1614B
Connection Speed:Up to 800 Mb/sec
Sub-units:
My Book Unit:
Unit Software Version:0x10483
Unit Spec ID:0x609E
Firmware Revision:0x1010
Product Revision Level:1010
Sub-units:
My Book SBP-LUN:
Capacity:2 TB (2,000,392,994,816 bytes)
Removable Media:Yes
BSD Name:disk7
S.M.A.R.T. status:Not Supported
Volumes:
disk7s1:
BSD Name:disk7s1
Content:EFI
Mountain Lion Clone:
Capacity:666.28 GB (666,279,542,784 bytes)
Available:296.02 GB (296,023,621,632 bytes)
Writable:Yes
BSD Name:disk7s2
Mount Point:/Volumes/Mountain Lion Clone
Content:Apple_HFS
Volume UUID:62C1F278-E1A6-3CB0-AE5A-A91DEDEA2CC2
Recovery HD:
Capacity:650 MB (650,006,528 bytes)
BSD Name:disk7s3
Content:Apple_Boot
Volume UUID:9B12704C-1C1E-35B8-B51C-8D1410333C49
Snow Leopard Clone:
Capacity:666.8 GB (666,797,666,304 bytes)
Available:289.54 GB (289,544,548,352 bytes)
Writable:Yes
BSD Name:disk7s4
Mount Point:/Volumes/Snow Leopard Clone
Content:Apple_HFS
Volume UUID:E93F1698-C976-3A56-82A7-72BCE67DDFFD
AVCHD Backup:
Capacity:666.19 GB (666,187,587,584 bytes)
Available:178.48 GB (178,475,245,568 bytes)
Writable:Yes
BSD Name:disk7s5
Mount Point:/Volumes/AVCHD Backup
Content:Apple_HFS
Volume UUID:1C5741BA-14FC-3175-B720-E3A0FA403F9C
My Book Device Unit:
Unit Spec ID:0x609E
Sub-units:
My Book Device SBP-LUN:
My Book:
Manufacturer:WD
Model:0x1105
GUID:0x90A99696C0B865
Sub-units:
My Book Unit:
Unit Spec ID:0x609E
Firmware Revision:0x1017
Product Revision Level:1017
Sub-units:
My Book SBP-LUN:
Capacity:6 TB (6,001,169,186,816 bytes)
Removable Media:Yes
BSD Name:disk5
Volumes:
disk5s1:
BSD Name:disk5s1
Content:EFI
TimeMachine:
Capacity:6 TB (6,000,825,212,928 bytes)
Available:293.11 GB (293,111,095,296 bytes)
Writable:Yes
BSD Name:disk5s2
Mount Point:/Volumes/TimeMachine
Content:Apple_HFS
Volume UUID:8558CFBC-7588-3D24-895D-533351C0A14C
Unit Spec ID:0x609E
Sub-units:
Built-in Hub:
Unknown Device:
Maximum Speed:Up to 400 Mb/sec
Connection Speed:Unknown
I was able to get the SnowLeopard Partition to Run
I then used DiskWarrior on the Broken MountainLion Clone
Re :installed MountainLion on top of it, Updated to latest Mountain Lion
Then superdupered back to my original wiped Velociraptor Drive
That worked. My Movies located on a seperate external WD drive happened to not be connected at install! (lucky me!) and seem fine and connect to iMovie and Final Cut Pro.
My iTunes files and photos located on a seperate bay drive also a WD drive BUT NOT PARTITIONED
Revision:80.00A80
Queue Depth:32
Removable Media:No
Detachable Drive:No
BSD Name:disk1
Bay Name:Bay 2
Volumes:
disk1s1:
BSD Name:disk1s1
Content:EFI
Media 1:
Capacity:2 TB (2,000,054,960,128 bytes)
Available:560.06 GB (560,058,359,808 bytes)
Writable:Yes
BSD Name:disk1s2
Mount Point:/Volumes/Media 1
Content:Apple_HFS
Volume UUID:72315CF7-E27D-31D8-9884-207B2E94AC8C
Seem absolutely fine.
The Time machine located on the other firewire connected MyBook, but turned off for update also is a bit broken but only about 450G, the original Velociraptor disk files and changed files going back are missing, but that might be fixable if I could be bothered. All the rest seems accounted for.
The DroboPro is another matter, and was the “other backup” having large sparsedisk bundles used for copying the other disks both internal and external. Can’t get it to play currently, Drobo Dashboard can’t access it, the data will be gone I suspect.
Thank heavens I am so obsessed with backups, and still have disks I havn’t needed to plug in that have retrospect backups on them.
Most are Western digital, but then this update also broke my DroboPro backups.
Very sorry for anyone who looses data permanently
People with apparently damaged drives should seek help, especially for the guy with his
PhD thesis on it…YIKES !! I hope YOU have more than one copy of that!
Regards to all…
