The script works great if you already have the WDMyCloud default install. I now currently have the openmediavault img installed but would like to go to the clean debian install instead. Is there an easy way? Can you write a script that can switch between the two images?
## BEGIN ## sharename = Public # [Public] path = /DataVolume/shares/Public comment = Public Share public = yes browseable = yes writable = yes guest ok = yes map read only = no ## END ##
## BEGIN ## sharename = SmartWare # [SmartWare] path = /shares/SmartWare comment = SmartWare public = yes browseable = yes writeable = yes guest ok = yes map read only = no ## END ## ## BEGIN ## sharename = TimeMachineBackup # [TimeMachineBackup] path = /shares/TimeMachineBackup comment = TimeMachine public = yes browseable = yes writeable = yes guest ok = yes map read only = no ## END ##
2. smb-global.conf
[global] load printers = no printable = no log file = /var/log/samba/log.smbd max log size = 50 deadtime = 30 enable core files = no security = user encrypt passwords = yes passdb backend = smbpasswd:/etc/samba/smbpasswd create mask = 0775 force create mode = 0775 directory mask = 0775 force directory mode = 0775 local master = yes domain master = no preferred master = auto os level = 5 use sendfile = yes dns proxy = no idmap uid = 10000-65000 idmap gid = 10000-65000 admin users = null passwords = yes map to guest = bad user guest account = nobody force group = share unix extensions = no acl check permissions = false max protocol = SMB2 browseable = yes syslog = 1 socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=2048000 SO_SNDBUF=2048000 min receivefile size = 16384 smb encrypt = disabled writeable = yes delete veto files = true
## Note: be careful when setting “dos filemode=yes”. We have seen where Samba does not ## handle this properly (and crashes) upon a rename of a file where the authenticated user is not the owner. ##dos filemode = yes
When you add jessie as a repository and apt-get install samba - it wants to upgrade a whole pile of other things as well and jessie is still in testing stage. Maybe not completly optimal - I’m not sure.
WSGVET → You have a great myCLoud to PC rate - wonder why the PC to myCloud is still slow compared to WD firmware.
Since wdMycloud firmware still has very fast speed in comparison - what version of samba was it? (‘smbstatus’ --version from SSH)
Is there any way to grab the files for samba direct from the WD firmware and then install using Fox’s replacement method? Could be an optimized build for the hardware.
I managed to run out of disk space testing plugins during installation. I had some large files in my home dir from testing that should have been deleted as well.
I removed everything and cleaned up but I am not sure I got all the space back.
Can someone with a relatively clean install post the output of df?
I currently have:
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 1968336 1246744 621604 67% /
/dev/root 1968336 1246744 621604 67% /
With all my hacking around learning this new system - I am thinking a nice new install of the system might be a good idea.
Can I just reflash using the autoinstall script again? i.e. same method that I used to move from the WD firmware? Is it possible to autoinstall back to WD firmware? Or do you have to take the drive out of the enclosure and follow the full repair procedure.
I need some extra modules to mount encrypted LUKS partition images, so I need to compile the kernel modules.
I saw your instructions in “New Kernel and System.txt” but I don’t know which kernel source to use. ¿gpl-source-sequoia-04.00.01-623.zip (latest source code in WD official site)?
¿Is your debian compiled with 64K pagesize as the new official firmware from WD?
Do you have the kernel and rootfs for original firmware saved on your drive somewhere? Or can I just dpkg -i the deb file to restore to default firmware. I extracted one of the deb files and found a rootfs but no kernel so I don’t think that’s right.
Reason I am asking is that I ran into buffering issues today with the kids streaming today to their ipads - until I can sort out the samba speed issues - I need a way back to original firmware preferably without cracking the case.
hello, i install OMV 1.0.24 with the debian_jessie_omv package with the guide, everything worked good.
but i have a problem, im trying to install owncloud plugin from the plugin section and i get this error mesage
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
openmediavault-owncloud : Depends: owncloud (>= 6.0.4) but it is not going to be installed
