Just a couple of silly questions before I start bothering the people on the OMV forum =)
In the web interface if I change the hostname the WebGUI is still accessible at the same address ( http://mycloud.local/),,) is that normal?
Something less silly, here the filesystems I found:
/dev/md0 ext3 1.88GB / 983.71MB used, I guess this is the OS (OMV)
/dev/md1 ext3 unomounted, and if mounted same size 1.88GB / 1.03GB used (is this my wrong previous attempt at installing OMV without a clean debian first?)
/dev/sda4 ext4 the remaining of the 4TB disk wich I mounted and I presume it’s where my shares will be
Please should I delete /dev/md1 and reallocate that space to /dev/sda4 ?
Hello, I have WD My Cloud with broken hard drive, I can use this method to install a new one ? I need to use only WD hard drive or I can to use another brand ?
I cannot run ISCSI module in omv. Any suggestions?
Failed to execute command ‘export LANG=C; update-rc.d ‘iscsitarget’ disable 2>&1’: update-rc.d: using dependency based boot sequencing insserv: warning: current start runlevel(s) (empty) of script iscsitarget' overrides LSB defaults (2 3 4 5). insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script iscsitarget’ overrides LSB defaults (0 1 6). insserv: warning: script ‘iscsi-target’ missing LSB tags and overrides insserv: There is a loop between service minidlna and iscsi-target if stopped insserv: loop involving service iscsi-target at depth 2 insserv: loop involving service minidlna at depth 1 insserv: Stopping iscsi-target depends on minidlna and therefore on system facility `$all’ which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header
HI guys, new to the NAS. I ot a 4tb my cloud (white one), I want to swap the HDD for a 1tb ater hearing the recovery process if it fails to be problematic because of the file system. After searching for alternative OS I sae OpenMediaVault .
to make the post shrt here are my questions.
my setup, win8.1 desktop and a MacBookPro.
I want to be able to recover the data if it fails with ease… I can have access to linux installing it on an small hdd on my Win Desktop.
is it possible to connect the hdd to win 8 to backup files directly without using the NAS unit? I readthat with WD OS is not possible, is it with OpenMediaVault?
is the NAS always spinning the hdd even if it is not copying files?
is it worth it to swap the hdd? I was thinking on keeping non important files on a 1tb inside the NAS after using the guide for swapping disc. I’m pretty sensitive about the hdd corrupting data while transfering or copying and losing data. (happened once with an external usb2.0)
For now - i using Clean debian. Runs perfect (Except samba’s speed - only 40-60MB/s. But its enaught for me)
Installed Transmission (from sid), Minidlna, Apache2/mysql/php5 for webhosting and my test projects, rSync, few chroot’s (For build packages and test some stuff)
hi i follow this steps https://drive.google.com/file/d/0B_6OlQ_H0PxVejVic2ZubXBfbHM/view?usp=sharing, all its ok, but wen i put HD on mycloud i wait more than 15min, and nothing, front led turn withe and pass few time turn off and turn on again, leds from ethernet port; status led always off, activity led blinking all time
i restart from step 1 and now all finish ok, but i connect hd to mc and nothing,reconect hd to pc and i see after reboot lose /dev/md0…this part of log from UART
[9.568987] async_waiting @ 1
[9.571975] async_continuing @ 1 after 0 usec
[9.576408] md: Waiting for all devices to be available before autodetect
[9.583234] md: If you don't use raid, use raid=noautodetect
[9.588936] async_waiting @ 1
[9.591921] async_continuing @ 1 after 0 usec
[9.597324] md: Autodetecting RAID arrays.
[9.601451] md: Scanned 0 and added 0 devices.
[9.605942] md: autorun ...
[9.608751] md: ... autorun DONE.
[9.612324] EXT3-fs (md0): error: unable to read superblock
[9.724190] List of all partitions:
[9.727713] 0800 80042207 sda driver: sd
[9.732369] No filesystem could mount root, tried: ext3
[9.737763] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(9,0)
[9.746129] [<c4015fc8>] (unwind_backtrace+0x0/0xf8) from [<c44f86bc>] (panic+0x5c/0x190)
[9.754387] [<c44f86bc>] (panic+0x5c/0x190) from [<c46f4c4c>] (mount_block_root+0x238/0x288)
[9.762881] [<c46f4c4c>] (mount_block_root+0x238/0x288) from [<c46f4e24>] (prepare_namespace+0x124/0x178)
[9.772524] [<c46f4e24>] (prepare_namespace+0x124/0x178) from [<c46f48d4>] (kernel_init+0x16c/0x1a4)
[9.781744] [<c46f48d4>] (kernel_init+0x16c/0x1a4) from [<c400faac>] (kernel_thread_exit+0x0/0x8)
[9.790684] CPU0: stopping
[9.793425] [<c4015fc8>] (unwind_backtrace+0x0/0xf8) from [<c4014764>] (handle_IPI+0xf0/0x15c)
[9.802097] [<c4014764>] (handle_IPI+0xf0/0x15c) from [<c400e538>] (__irq_svc+0x38/0x90)
[9.810243] [<c400e538>] (__irq_svc+0x38/0x90) from [<c400fb0c>] (default_idle+0x24/0x28)
[9.818472] [<c400fb0c>] (default_idle+0x24/0x28) from [<c400fcc4>] (cpu_idle+0x84/0xcc)
[9.826616] [<c400fcc4>] (cpu_idle+0x84/0xcc) from [<c46f471c>] (start_kernel+0x284/0x2d0)
[9.834930] [<c46f471c>] (start_kernel+0x284/0x2d0) from [<04008040>] (0x4008040)
[9.842459] Rebooting in 3 seconds.
