Thx for the feedback Joey…I’ve been working on this and one big dissapointment is that since i have a 2TB USB drive plugged into the the hub it separates the movies on it from the movies actually on the hub itself. The only way i can see all my movies in one list is to NOT filter by folder…
BROWSING----
Pre folder categories :
VIDEO > (then) MOVIES
Post folder categories:
VIDEO > (choose) USB2 or Media Hub > (then) MOVIES >
The latest Firmware has a ‘source’ filter “Media Library” which collates media from all sources (i think)
However, as you may be aware of … latest firmware does not support PNG’s + a number of other things that worked fine in older firmware… which are now either missing or broken.
This confuses me just a little. I was extracting the theme and saw a number of .png files being extracted. Will this theme work fine with the latest firmware?
The WD supports PNG files within the theme files themselves
The WD does not support PNG files for moviesheets or movie images or folder images
Some people have reported it sort of working I think on the latest firmware however it is designed for firmware 2.07
